Case 800-Help on Price Eagle Hitch
Steve-MN
09-09-2004 19:18:13
Hi all,
I found a Case 800('58) in New Ulm MN. Seems to be in great shape. Not a dent on it. All original, nothing missing. Paint rough. Very few oil leaks. Starts & runs great. Case-O-Matic. Last 25 yrs it's been a PTO tractor & snow tractor. Clutch may need work. Hitch pin hole still round. Guy wants $3,250(he's 3rd owner). Seems a tad high--what's it worth? Also, how do I attach a back hoe to the eagle hitch? Can I convert Eagle to 3 pt?.
Thanks for any advice.
Steve
INCase
09-10-2004 05:30:05
 Re: Case 800-Help on Price Eagle Hitch in reply to Steve-MN, 09-09-2004 19:18:13
seems a bit high if not restored. You can get more tractor for that $ or the same for less $. Take your time and shop around.
caseman-d
09-09-2004 19:46:47
You want to spend 3250 on a tractor and then add a bachoe. Why not just buy a bachoe. You are limited to what you can use the aftermaket hoe attachments for. By buying a complete unit then you have the stabilizers to sturdy the unit. Oh yes, may need clutch, hope your referring to pto clutch. I'm sure that could get pricey. The eagle hitch is Case.s version of a three point. Depending what catergory the backhoe attacment requires the eagle hitch may work. If you really want to spend that kind of money I got a 800 that I would sell for 2500.00. PTO clutch worked fine last time used.With money and right tools anything can be accomplished.
caseman-d
Steve-MN
09-12-2004 16:33:56
 Re: Case 800-Help on Price Eagle Hitch in reply to caseman-d, 09-09-2004 19:46:47
Caseman,
Thanks for the advice. You're right, I should probably just buy a used backhoe loader. The 800 with that Case-O-Matic is kinda scary also. I'll keep looking.
Thanks,
Steve
