Brakes on 970 case
RickyP
09-09-2004 08:23:07
I need some help on the brakes on my tractor. It is an early model with power brakes. When you engage the pedal it will not stop the tractor. Is there a place to put brake fluid or does it run off the hyd fluid? I have the service manual but, it doesn't tell me much. Thanks, Ricky
R.D.F.
09-09-2004 17:12:18
 Re: Brakes on 970 case in reply to RickyP, 09-09-2004 08:23:07
You may have brakes that operate off brake fluid, seperate of the hyd. system, do you have reservoirs in front of the fire wall? Dale
deller
09-09-2004 14:36:13
It is supplied with hydraulic fluid from the power steering circuit,
