770 hydraulic pump
jboy377
09-09-2004 07:32:04
I have a 770 case with trans problems,It's 2nd & 3rd shift lever moves freely and when in first gear it clunks now and then when moving qusstion is do I have to remove steering wheel back to the fuel tank as a unit to remove the top of the trans to find the problem, also does anyone have a manual for this 770 agra-king thanks John
jboy377
09-10-2004 06:23:36
 Re: 770 hydraulic pump in reply to jboy377, 09-09-2004 07:32:04
Thanks for the help.also found a manual John
JCmarleau
09-09-2004 20:42:45
I would have a parts manual my e mail is [email protected]
deller
09-09-2004 14:45:53
Check to see if there is an inspection plate on the trans top plate. You have probably broken a shift fork. You should be able to remove the trans. cover by first removing the battery box. Raise the cover up and forward and once shifters are free tie them up. Cover will slide sideways and out. Not easy.
jboy377
09-09-2004 07:35:29
sorry not hyd. pump but trans problem John
