case 800 fuel filters
Kelvin
09-08-2004 21:33:38
What is the part number or type for the final fuel filter. I am trying to get a 58' Casomatic 800 started (been 15 years since last ran) and can't seem to get the fuel thru the final filter. The filter that was on the tractor was a napa 3191 and we had a new spare and i tried it but still no luck. The line leading to the filter has ample fuel supply when removed. Any other suggestions on what to do help get the tractor started are welcome.
caseman-d
09-09-2004 20:15:54
 Re: case 800 fuel filters in reply to Kelvin, 09-08-2004 21:33:38
Well I would start out by losing the injector lines at the pump. Use your decompression lever so the tractor will turn over faster. I thought I had that problem also on my Case 900 (6 cylinder vs 4 cylinder). Turned out my problem was that when I shut the tractor off the shut off stuck in the off postion. After tearing my hair out and half the pump apart we got it running, 3 months later it wouldn't start again, about a year later I found out why(didn't pay enough attention first time). I found out on a Massey harris that had the same filter that we didn't think it was allowing fuel through. After removing the hose from the pump and cranking it finally started pushing fuel. What you might do is try putting a low pressure gauge on the secondary filter and see if you get any pressure there. It think 5lbs will be plenty. I filled my final filter full thinking that was the problem, but it wasn't. I think you will find a simple solution.
caseman-d
kelvin
09-09-2004 13:56:36
Just to clarify the original question. The fuel comes out (gravity) fine out of fuel line connecting to the top of the 3191 filter in ample quanities. But the fuel doesn't want to fill the final filter. Seems as if the filter check valve could be incorrect for this application. So I am wondering if this is the correct filter or not and what filter would accually work. The original owners manual and IT service manual both say the gravity line (when by-pass valve is open) will allow fuel to fill final filter.
Note: My dad has had the tractor since the 60's but when the final filter was changed 15 years ago or so the tractor would never restart. My dad has stated that he could never get the air bleed out of the system. ( I was 13 at the time) i am starting to wonder if he was given the wrong filter at that time and if this has been the problem all along. As a side note I have completely drained, cleaned, and refilled the fuel system from tank to final filter but not thru final filter and injector pump and injectors, as i cannot get fuel to fill the filter and bleed the system with new fuel)
Doc Larry
09-09-2004 17:38:45
 Re: case 800 fuel filters in reply to kelvin, 09-09-2004 13:56:36
Kelvin,
Thanks, I understand better now. Sorry I can"t help with a filter number, however, I did go the Baldwin site>Link
I might add that the Baldwin spec page shows a reverse flow valve at inlet on this filter, which sounds like a check valve. If the lines are hooked up backwards a check valve would prevent flow.....
Larry
Doc Larry
09-09-2004 17:46:11
 Re: case 800 fuel filters in reply to Doc Larry, 09-09-2004 17:38:45
Kelvin,
In addition, if this is indeed a spring loaded check valve, you might need a little more pressure than gravity to open the valve and fill the filter(assuming the NAPA valve also has one and that the original Case filter didn't). You might just try bleeding this filter by cranking the engine with the decompression lever activated if you haven't already.
Gravity feed from the tank to the filter amounts to very, very little pressure - 1 foot of drop is less than 0.5 psi...
Larry
Doc Larry
09-09-2004 05:21:27
Kelvin,
I"m not real familiar with this particular model, but if you replaced the final filter that probably isn"t the problem assuming that you installed it correctly. You probably have a pressure relief valve between the primary pump and filter - 15 year old fuel means gum, so I"d check to see if that relief valve might be stuck open. If so, acetone and alcohol, or carburetor cleaner wil get the gum off pretty well.
Also, if you haven"t thoroughly cleaned the tank and the rest of the fuel system up to the final filter, you will probably clog filters up very quickly.
Larry
