SC Valves
Glenn FitzGeral
09-07-2004 20:33:16
Does a '54 SC have valve seals? I haven't even taken off my valve cover yet but with my compression readings all 100+ I'm looking for reasons why the engine smokes as much as it does, fouls plugs, etc. Thanks, Glenn F.
C. Amick
09-08-2004 12:44:29
 Re: SC Valves in reply to Glenn FitzGerald, 09-07-2004 20:33:16
It's probably your piston oil rings. I don't think it has valve stem seals. The only other thing I can think of is that the oil return ports in the head might plugged up and there is too much oil standing in the head. Smoking tractors and stuck piston oil rings have been a previous topic of discussion on here. Some of the guys got theirs freed up using penetrating oil, but I put new rings on my tractor and that fixed the problem.
DCTOM
09-08-2004 07:04:45
YOU CAN HAVE GOOD COMPRESSION RINGS BUT OIL RINGS CAN BE STUCK OR BROKEN
todd hamilton
09-08-2004 17:50:00
 Re: SC Valves in reply to DCTOM, 09-08-2004 07:04:45
That piece of ring I found in my oil pan must have been part of an oil ring!:^)
