Solenoid - multiple failures
Mike_IN
09-07-2004 07:27:29
I just replaced another solenoid on my 611B. That makes three in one year.
The system is 12 volts. The solenoid is for 12 volts.
Any idea"s why the solenoid is failing at this rate?
DKase
09-08-2004 06:32:25
 Re: Solenoid - multiple failures in reply to Mike_IN, 09-07-2004 07:27:29
Low voltage from your switch will cause the solenoid to be sluggish and not make good connection. We have had that trouble with the 30 and 70 series tractors. To solve the problem you need to install another solenoid (such as a Ford car starter sol.) on the starter and wire it up so your wire from the switch activates the (Ford) sol. Use a 10 gauge wire and wire the hot side of the sol. to the battery, and the switched side to the pole on the original Case sol. where you removed your switch wire. We have done this with all 6 of our diesel tractors and have cut our starter trouble by 90%. Good Luck DK
Mike_IN
09-08-2004 09:10:46
 Re: Solenoid - multiple failures in reply to DKase, 09-08-2004 06:32:25
Thanks. There is low voltage coming from the switch.
