LA Rims
LALA land
09-06-2004 21:30:35
its a 1948 LA and i just got new tires. busted the old off the rims, which weren't a matched set and one is 15" wide, and the other 13". in all my books, the only thing i can determine, is that you generally put 4# more pressure in the furrow tire. cannot find any reason other than an accident to explain the difference in width...
any one want to educate me?
DCTOM
09-07-2004 10:13:10
 Re: LA Rims in reply to LALA land, 09-06-2004 21:30:35
I AM SURE BOTH RIMS WERE 13" FOR THE LA'S THE 4# MORE IN FURROW DTIRE IS FOR THE ADDED WEIGHT ON THAT WHEEL WHEN IN THE FURROW
LALA land
09-07-2004 16:30:53
 Re: LA Rims in reply to DCTOM, 09-07-2004 10:13:10
was almost sure that they had been mis matched, but wanted to make sure. i've got a parts tractor, that has 15's on both sides, so i can correct the one that runs...thanks a million fellas!
LALA land
09-07-2004 06:49:58
i guess, i was asking if the la was either equipped with two different width rims on the rear, or someone maybe set it up that way on purpose, for a reason??? i sort of think it was an accident, as i can find nothing in the operators or service manual...what are your thoughts?
Bill Hires
09-07-2004 10:13:08
 Re: LA Rims in reply to LALA land, 09-07-2004 06:49:58
The LA parts book gives the following tire sizes, 14:00-28, 14:00-30, 15:00-30, 12:75-28, 18:00-26 & 13.50-28. Rim sizes are, 8:00 T-28, 12-30, 16-26 & 14-30
Someone has mismatched the rim/tires.
vern
09-07-2004 06:14:50
What is your question? It sounds confusing to me, and your only question is "Anyone want to educate me?" What do you want to know? Sorry I dont understant.
