Vac gear grinding
Gerald
09-06-2004 18:43:56
I've posted before about this. Have 49 VAC with Kingston Hydraulic (on belt pulley side). Have a blade in back that I use for sno removal. The only way I can make the shift without grinding the gears is to fool with the hydraulics until some internal mechanism releases and then it shifts without a problem. This is getting to be a nuisance and would like to address it before the sno starts flying again here in Minnesota. Anyone have a clue as to the problem. My clutch adjustment is maxed out--so can't do much from the outside, I'm thinking. Is this a clutch or worn part problem? If something were just sticking, you'd think it would unstick by now since I used it all last winter to plow sno. Appreciate your comments.
Old Man Winter
09-06-2004 19:06:16
 Re: Vac gear grinding in reply to Gerald, 09-06-2004 18:43:56
You have about two weeks!
