case lp tractor
case puller
09-06-2004 16:32:24
What was the biggest case lp tractor built.? I know there was a 970 lp but was wondering if there was anything with more cubic inches
Walter
09-07-2004 17:18:58
 Re: case lp tractor in reply to case puller, 09-06-2004 16:32:24
How many does the 970 have? I have a propane LA bored to 4 7/8 that has around 448 cubic inches or in that neighborhood.
case puller
09-07-2004 18:01:19
 Re: case lp tractor in reply to Walter , 09-07-2004 17:18:58
I believe a 970 is the same as a 930 at 377 cubes.
Don Rudolph
09-07-2004 20:41:39
 Re: case lp tractor in reply to case puller, 09-07-2004 18:01:19
The 930 has a 401 cu. in. motor and I believe the 970 does also.
case puller
09-08-2004 04:00:12
 Re: case lp tractor in reply to Don Rudolph, 09-07-2004 20:41:39
The 930 was 401 with the diesel and 377 in the lp and gas engines.
Don Rudolph
09-08-2004 15:34:27
 Re: case lp tractor in reply to case puller, 09-08-2004 04:00:12
Thanks for setting me straight on that. I'm surprised that Case still used the old 900 and 600 configuration on the 30 series.
mike's600
09-07-2004 05:13:08
I have a Case 600 LP for-sale , m&W overbore kit, straight tin.
Roger H
09-06-2004 18:10:25
I am not aware of any 70 series LP tractors & there was no 1030 LP's
DCTOM
09-06-2004 17:15:50
930. and maybe the 1030
Dale Merkle
09-07-2004 10:27:43
 Re: case lp tractor in reply to DCTOM, 09-06-2004 17:15:50
I have a 930 propane that hasn�t run in three years, a couple weeks ago we tried to start it with limited success. We can get to idle around 6oo RPM but will not run at a higher throttle setting. I have had the whole system apart and can find where the problem is. Any one have any ides? (MO)
