Case 885 won't stsart after fuel filter change
Phil Evans
09-06-2004 08:33:33
Just changed both fuel filters for my Case 885 and now cannot start. I was warned to never let run out of fuel and I'm afraid that the filter change was the same thing.
Edie in Ky
09-10-2004 22:26:24
 Re: Case 885 won't stsart after fuel filter change in reply to Phil Evans, 09-06-2004 08:33:33
Yep, its the same thing all right. Your gonna have to bleed the entire fuel system. If you don't nhow let me know. I have an 885 and have done this several times due to changing fuel pump and/or filters.
Phil in KY
09-12-2004 09:42:46
 Re: Case 885 won't stsart after fuel filter change in reply to Edie in Ky, 09-10-2004 22:26:24
Thanks Eddie for your reply! and I was well underway with a first time and seeming unsussful fuel system bleed when I tried a little bleeder valve screw on the fuel injector carb sys. Once I opended this and turned ignition and let some of the fuel run out of the opening until I got a steady flow, and then put screw back in place and waited just a few min. Tried to start again and it FIRED up quickly and is running much better now.
