SC Compression Questions
Glenn FitzGeral
09-05-2004 12:10:27
I put the SC to work a little for the first time since buying it. I'm not so sure about some of the numbers the salesman told me upon my buying it sight unseen 425 miles from here. It was promised to have 130 lbs. compression on all 4 cylinders and 30 lbs. of oil pressure. I have 10 w30 motor oil in it at present.(I need to put in straight 30) Oil pressure is 20 lbs., engine one third throttle, engine warm. Compression is 120, 120, 110, and 100 with tractor running. It is 45, 85, 65,and 85 when just turning it over with starter. Engine smokes and likes to fowl plugs. Got ahold of the original owner. He says it had a complete valve job about two years ago. Tractor has done a LOT of sitting in the last 30 years. I plan on hooking up a mounted sub soiler soon and working the pants off it when I put in the heavier oil in attempt to seat up the piston rings. Question is: How do I test compression?...With the starter or with it running. What compression SHOULD it have? Thanks, Glenn F.
todd hamilton
09-06-2004 06:20:30
 Re: SC Compression Questions in reply to Glenn FitzGerald, 09-05-2004 12:10:27
Some smokin' SC tips (I have one)! Take the access cover off of the oil pan and check to see if there are any pieces of ring laying in there. While you have that off, clean all of the sludge from the bottom of the pan and the screen - it will help the sending unit raise the oil pressure slightly. If the gauge is not an original low pressure you may be getting a little more than you think - SCs do not produce a lot of oil pressure (30 lbs when new - anything over 20 acceptable). If your tractor has an oil filter consider checking the pressure directly from the engine block - you may get a more accurate reading. Finally, I am having good luck with Pennzoil 15W40 Gas/Diesel Heavy Duty available at TSC. It doesn't burn oil near as bad. My oil consumption has steadily dropped in the five years I have owned my tractor, so there is something to getting the rings to reseat. If I was using my SC for field work, it would need to have a set of rings.
Camboted
09-05-2004 20:30:11
Glenn, I had a DC like that. It was promised to be in great shape, but I found low compression in one cylinder. It too had been sitting for along time. Finally I pulled it apart and the rings were so stuck into that piston I had to pry them loose. I put on a new set of rings and ran a hone through the cylinder (three passes) and the compression went right where it should have been. DCTom has had luck just working the snot out of them, getting them hot and breaking them loose that way.
Glenn F.
09-05-2004 21:21:13
 Re: SC Compression Questions in reply to Camboted, 09-05-2004 20:30:11
I went out to my brother's house tonight and hooked on the sub soiler. It has 13 teeth. I don't think it's a true sub soiler. I'm sure it will tame any wild thoughts the SC may have. I plan on putting it to work tomorrow. I am a little concerned about the slightly low oil pressure when I work it hard. I certainly don't want to blow it up. A little common sence will be in order! Glenn F.
Glenn F.
09-05-2004 13:02:23
I accidently got my compression numbers reversed. 45,85,65,85--running. 120,120,110,100--starter.
Joe (Wa)
09-05-2004 18:30:30
 Re: SC Compression Questions in reply to Glenn F., 09-05-2004 13:02:23
What Doc Larry said and check that choke fully open too. I like to put the battery up to full charge and than leave the charger hookedup. Check the amp draw on the charger, do one cylinder and then wait until the charger is back down to the original amp before doing the next cylinder.
Use a screw in adapter at the plug hole with a seal, not one of those press it against the hole type. The compressor tester should have a check valve that holds the peak pressure.
After you do one round, squirt some oil in each cylinder and turn the engine to get the oil spread down around the rings. Take another set of readings, that will give you an idea of the ring leakage. If it doesn't improve check the valve lash.
Most manuals allow a spread of 5 psi. But I wouldn"t be too concerned with up to 10 psi. If the ring leakage appears to be a problem, work the snot out of it a couple of days and do a dry check again to see if it is improving.
Joe
Doc Larry
09-05-2004 17:23:18
Glenn,
Standard procedure would be to test compression with the engine warm, all spark plugs out, and throttle open. Crank it with the starter for half a dozen revolutions or so. I don't know the actual specs on this engine but old tractors are not high compression, so I personally would be happy with around 100 - 120 psi or so. Sounds like you're okay.
