VAC Timing Marks..
Keith-OR
09-04-2004 10:05:15
Help on which demples to line up on timing gear and crankshaft. The crank gear has one temple and the timing gear has two demples, Have no way of knowing which demple on timing gear to use. Or do I line up one on crank between the two demples on timing gear. I would not be asking these questions if and I mean IF "Case dealer" had gotten my shop manual when they were suppose to. LOCAL CASE DEALERSHIP LEAVES A LOT TO BE DESIRED!!!!Wish I knew where to file complaint.
Thanks everyone for all your help so far.
Joe (Wa)
09-04-2004 10:42:29
 Re: VAC Timing Marks.. in reply to Keith-OR, 09-04-2004 10:05:15
The dimple on the crank gear is centered between the two dimples on the cam gear.
Joe
Thanks Joe
09-04-2004 17:13:37
 Re: VAC Timing Marks.. in reply to Joe (Wa), 09-04-2004 10:42:29
That is what I thought but wanted to put it out on here to get some feed back. Learned something today, pulled off crankgear and found some shims. All I am doing is removing .014 in shims so I will have .002 end play on the crank. Not really as hard as I thought it was going to be to get the end play clearance I needed. I thought I was going to have to buy new thrust washers. It has been a good day "learned something"....Keith
Joe (Wa)
09-04-2004 19:19:23
 Re: VAC Timing Marks.. in reply to Thanks Joe, 09-04-2004 17:13:37
Yeah the shim pack is for adjusting the end clearance. The shims come as 0.002" & 0.008", both still avail from Case.
Here are the nrs if you need some and your dealer cannot do the cross-ref:
0.002" VT3367 = A29292
0.008" VT3368 = A29293
Joe
Keith-OR
09-04-2004 19:51:31
 Re: VAC Timing Marks.. in reply to Joe (Wa), 09-04-2004 19:19:23
Thanks Joe. I have some shims on the motor I took off this tractor. It has a broken crankshaft and center main had spun. But still has a lot of good parts on it. I have the crank thrust clearance set now. Putting everything back together. Hopefully will put the motor back on tractor tomorrow. Again thanks for all the info, Joe.
Keith
