VAC motor
Keith-OR
09-03-2004 20:42:19
I have my VAC 14 engine back together ,but I seem to have a crankshaft related noise. The only thing I can figure out is that there is to much end play in the crank. Can anyone give me the thrust bearing end play clearance. I seem to have at least .014 end play.
Thanks Keith.
Joe (Wa)
09-03-2004 21:21:39
 Re: VAC motor in reply to Keith-OR, 09-03-2004 20:42:19
Case manual spec is 0.003" - 0.005".
Joe
Keith-OR
09-03-2004 21:37:57
 Re: VAC motor in reply to Joe (Wa), 09-03-2004 21:21:39
Thanks Joe. I guess that would account for the crank slap that I have. Sure sounds like a rod bearing, if I hadn't plastigaged the rods bearing would have swore that was the noise. I had to really look to find the crank moving back and forth. So i guess i will go to the case dealer and see if I can get some more thrust washers.
Thanks again Joe.
