How different is VA1 from VA?
swamp farmer
09-03-2004 11:17:08
I'm going to an auction next month that lists a VA1, not running. I'm wondering if I could use it as a parts tractor for my '51 VA. There must be lots of parts that are compatible, right?
Any help appreciated.
Gene Dotson
09-03-2004 16:42:23
 Re: How different is VA1 from VA? in reply to swamp farmer, 09-03-2004 11:17:08
The VAI uses a heavier front axle with a thicker beam and bigger wheel bearing journals and an extra support. The whole assembly will fit the VA. Transmission gearing in most VAI"s is faster than the VA. Virtually all other parts are the same... Gene
DCTOM
09-03-2004 14:02:12
YEP; MOST ALL PARTS WILL WORK FOR YOU,
swamp farmer
09-05-2004 06:09:47
 Re: How different is VA1 from VA? in reply to DCTOM, 09-03-2004 14:02:12
That's good news - thanks. Now all I have to do is figure out a maximum price I'm willing to spend on it. Sure hope the tires are in better shape than my own.
