Case 450B trans overheat and malfunction!!
Jon Ludden
09-03-2004 08:21:34
Hi all,
I have a 1980 case 450b with a 207d engine. The dozer runs good and has had the torque converter rebuilt recently but after a couple of hours of medium load the torque converter will slowly get hot. Sometimes when this happens the dozer will stop completely as if dropped into neutral. After it cools down it runs normally. I have changed the charge pump screen (charge pump is relatively new) and all other hydraulic filters I can find. Could a pressure release valve sticking open a little cause the tranny to overheat? Could this also stop it from moving altogether? Is it possible that my charge pump is going out already and contributing to the problem. I have no guages and no access to any and unfortunately the trans pressure guage is broken. (can"t get scrooge boss to buy anything) If any of you guru"s have seen this or anything like it I would appreciate some pointers to get me going in the right direction, although I would prefer a spot-on remedy ;)
Jon,
Max
09-04-2004 17:09:56
 Re: Case 450B trans overheat and malfunction!! in reply to Jon Ludden, 09-03-2004 08:21:34
Its very hard to troubleshoot those tranny's without a pressure guage. Things that can make it overheat is to low of pressure and/or the clutch packs are leaking more that the 12 oz per minute. Since you have no guages, have you checked the lower hose on the trans to the pump? these can start to collapse with a little temperature and then cause the pump to work harder creating more heat.
