Case 1941 S - What is it worth
Neal
09-02-2004 18:09:35
I am looking at a 1941 Case S. Can anyone give me an idea as to what it is worth? I heard it run today and it started right up and did not smoke. It has an auxiliary gas tank mounted towards the front of the hood. The only thing wrong that I can see is that the nose is bent in and the fenders need some work.
Thanks in advance for any comments.
Neal
09-04-2004 05:45:08
 Re: Case 1941 S - What is it worth in reply to Neal, 09-02-2004 18:09:35
Thanks for the comments.
I did get to see this tractor sell at Polk's auction yesterday. I walked away as it sold for $2000. I thought that was too high of a price to pay. I have a 1949 S that is 99% restored and right now with all of the parts that I have had to put into it, I only have about $1200 in it. That was the price that I thought it would be worth, but just wanted to get some other thoughts as well.
caseman-d
09-05-2004 07:05:48
 Re: Case 1941 S - What is it worth in reply to Neal, 09-04-2004 05:45:08
Where are you located at. Must be a higher demand for them where your at or there were 2 people that has to much money. Guess I better be getting mine running as it sounds like they may be going up in value. Am glad to here the guy got that kind of money for them.
caseman-d
Neal
09-07-2004 08:17:19
 Re: Case 1941 S - What is it worth in reply to caseman-d, 09-05-2004 07:05:48
I am located in Central Indiana.
C. Amick
09-03-2004 11:01:41
Check the condition of the manifold and the tires and check for any cracks in the engine block (particullay around the carburetor). Value depends on your location as well. I would think it would be worth a little more than an "SC" in comparable condition, since the "S" is more rare.
jal-SD
09-03-2004 08:51:50
If its got a gas tank in the hood, it was originally a kero/dis burner. Not too many Case's were kero/dis burners, the # of gas was way more than kero/dis burners. Check the manifold, it should have a heat riser on it, too. Might make it worth a little more. Can't tell you what S's are worth, never saw one sell in our part of the world, but you can buy running SC's w/descent rubber around here for under $1,000. Hope this helps. (My $0.02 worth. jal-SD)
RussR
09-05-2004 16:06:08
 Re: Case 1941 S - What is it worth in reply to jal-SD, 09-03-2004 08:51:50
1941 Case Model SC; 4 cyl, 153CID D, xmsn 4F - 1R, 30 PTO HP, 4200 lbs, lo 700.00, mid 1280, hi 1510, This is for comparison only, my guide does not list a Model S. They had to be a bit rare with the aux. gas tank start then switch to kerosene. JD had many of these 2 fuel beasts.
