No oil to rocker arms on Case 500
Walter
09-01-2004 19:22:22
Oil pressure is good 15 lbs. Oil is going to the back and middle head rocker arms and pushrods. Oil is just dribbling out of the front of the rocker arm tube on the front head. No oil going to push rods. Any suggestions?
markalgood
09-02-2004 15:16:52
 Re: No oil to rocker arms on Case 500 in reply to Walter , 09-01-2004 19:22:22
if it is the same as case 400 there is an o ring on oil feeder tube that goes down into head if bad or missing could be your problem
Walter
09-04-2004 04:10:06
 Re: No oil to rocker arms on Case 500 in reply to markalgood, 09-02-2004 15:16:52
Oil is pooling where the oil feed line comes through the head. I don't see an o ring on the other heads. Don't know if there is a missing o ring or maybe a hole in the line?
C. Amick
09-02-2004 12:46:14
I'm not familiar with the 500, but if has the same spin-on oil filter as the 300, it should have a metal stem that goes up into the oil filter. Is it there? Without the stem on the 300, almost no oil goes to the head.
Joe (Wa)
09-01-2004 20:43:04
Walter, I am not sure about the engine in the 500 but the gas 148 engine in the 300 & others has a 2 piece rocker arm tube. The oil hole in the rocker arm bearing is at the top and the feed holes from the tube must be postioned facing toward the valves. When the rocker arm is rotated down to open the valve, the two holes are closer together and there is less resistance to oil flow. Perhaps your front tube is in 180 degs out.
Joe
george md
09-01-2004 20:42:01
Walter,
I had a similiar problem with a 6 cyl
401 engine (1150 crawler ), some one before
us had the rockers of the shaft and reassembled
them with the shaft turned end for end , it puts
the oil holes in the wrong place. After some
digging in the service manual we found that info.
I am assuming that you have a good supply up to the rocker shaft, also that engine should have somewhat more than 15 pounds at anything above an idle .
george
