Pulley Brake Drum Needed
Glenn FitzGeral
08-31-2004 15:33:55
I need the pulley brake drum for my '54 foot clutch SC. Mine was in two pieces when I got the tractor. Anyone have one? Thanks, Glenn F.
AUSTEX
09-03-2004 08:47:03
 Re: Pulley Brake Drum Needed in reply to Glenn FitzGerald, 08-31-2004 15:33:55
I had the same problem on my 53SC. Although the flange part of the drum where it bolts on was still intact, the rim was almost completly worn off. I was able to find a piece of truck exhaust pipe tubing with the same OD, I think maybe 5 inch, and had a shop weld it to the existing flange. While not purfect it seems to work fine as this is just a spring loaded drag brake.
Good Luck
mike's600
09-01-2004 15:09:04
I will check to see if i have one.
