case 900
jesse
08-31-2004 10:40:01
im trying tofind out if you can bolt a 401 case motor in place of the 377 is it the same block
jesse p
09-02-2004 09:35:47
 Re: case 900 in reply to jesse, 08-31-2004 10:40:01
now your talking if its the same block as the 377 anybody else that can tell me its the same block
comfortking
09-02-2004 05:08:29
If you are going to that much trouble, why not put a 504 in it and the good "P" pump? Sure will turn a lot of dirt. Just put on some good side shields and a turbo silencer and let the games begin!
Roger H
08-31-2004 13:10:11
Why do you want to drop down from 6 cylinders to 4? A few weeks ago I saw a 2590 engine that is in a 1030.
Klyde
08-31-2004 18:20:49
 Re: case 900 in reply to Roger H, 08-31-2004 13:10:11
I"m thinkin he means a 401 MOTOR not a 401 Model. 401 is what the 930s used.
Roger H
08-31-2004 22:44:15
 Re: case 900 in reply to Klyde, 08-31-2004 18:20:49
Duh, you"re right Klyde, my brain wasn"t working earlier, should know that too, I"ve got 2 377"s & a 401 around here as it is, he shouldn"t have a bit of trouble switching them.
big orange
08-31-2004 11:33:02
I think the 30 series 401's will bolt in,I don't think the 70 series will.
jesse p
09-01-2004 17:58:59
 Re: case 900 in reply to big orange, 08-31-2004 11:33:02
the reason i ask is for antique tractor pulling. th erules around here say stock block so what the international guys are doing is putting a 301 in a 460. but if the 401 0r 451 are the same BLOCK as the 377 you would be real tough in antique and regular pulling with a 900
