SC Starter Oil Leak
Glenn FitzGeral
08-30-2004 05:12:49
I did some reading in the archives regarding peoples attempts to stop the oil leak where an SC starter enters the bell housing. While the starter is not designed for an o-ring as the DC is, couldn't a person use a fat o-ring anyway since the factory gasket is 3/16" thick. I would think this would work very well. I have to do something to mine today. Glenn F.
C. Amick
08-31-2004 09:41:49
 Re: SC Starter Oil Leak in reply to Glenn FitzGerald, 08-30-2004 05:12:49
One of my tractors some sort of rubber boot around the starter that someone fabricated. You can make a gasket using "silicone gasket maker". Pour a thick bead around the starter opening and let it set up good before installing the starter. Your rubber O-ring idea may work just as well.
Glenn F.
08-31-2004 15:29:57
 Re: SC Starter Oil Leak in reply to C. Amick, 08-31-2004 09:41:49
Thank you for your response. When working on the tractor yesterday I took a piece of approx. 5/16" neoprine hose, formed it into an o-ring by usinc a little piece of plastic tubing. It worked VERY well and looks good. Glenn F.
jal-SD
09-01-2004 06:29:04
 Re: SC Starter Oil Leak in reply to Glenn F., 08-31-2004 15:29:57
Original cork gaskets were avialable @ my C-IH this spring. I bought two of them but I think they were about $4.00(+) each. (My $0.02 worth. jal-SD)
