Roosa Master fuel pump
jad
08-29-2004 15:23:44
Just had my Roosa master pump reconditioned (580C). All running well except that it is leaking on all 4 high pressure lines at the point where they attach to the pump. The shop supplied new washers but even though I have torqued the nuts right down I am getting a leak on all 4 points, leading to a fuel drip about every 20 seconds when running.
Are there any better copper washers available that are a mite oversize?
Any help appreciated.
george md
08-29-2004 16:37:35
 Re: Roosa Master fuel pump in reply to jad, 08-29-2004 15:23:44
jad,
copper washers have not been used for at least 20 years , seems they won"t hold at the higher prssures. Make sure that there is no twist or out of square at the mating surfaces. Also the lines will crack where it is silver brazed to the fitting that the bolt goes thru . Washers are steel.
george
