Case C .. where do I find serial #
Darlene Harper
08-29-2004 02:03:22
I have a Case C on steel not sure of year. Needs to be restored and I would like to know what they are worth and where I can find the serial # so I can find out what year it is. Needs a gas tank and sediment bowl. Turned over a few years ago. Not sure what else it will need. THANKS.
Klyde
08-29-2004 17:11:01
 Re: Case C .. where do I find serial # in reply to Darlene Harper, 08-29-2004 02:03:22
And if it's old enough, and you don't have the tool box cover, it should be on the right rear of the engine block, just below the head.
Kent Fedor
08-29-2004 12:17:55
Also Sometimes the S/N was stamped on a flat little spot nest to where the seat spring mounts. At lest it is on my "37 CO. Kent Fedor
Tom (Ks)
08-29-2004 09:10:27
The S/N plate is on the tool box at the steering column and on the right side of the engine block. Down and to the rear, above the pan bolts.
