Case 830 Loader Hyrdrualics
Dozerboy450
08-28-2004 13:39:39
I'm sure it's a case to case issue but can anyone tell me if, when you push in the clutch on a typical 830, do you lose your hyraulic pressure? I am going to look at one tommorow and can't get a hold of the guy tonight. It has a loader and I wanted to know if I can raise and tilt the bucket with the clutch pushed in. I don't know if it is a front mount hydrualic pump or not. Any help would be greatly appreciated.
Jim B
08-28-2004 19:26:51
 Re: Case 830 Loader Hyrdrualics in reply to Dozerboy450, 08-28-2004 13:39:39
The 830 Hydrulic Pump is direct engine driven, clutch pedal does not disengage pump. It"s mounted at the rear of the axle housing, just forward of the control valves.
