More horsepower from 430
hiway
08-28-2004 09:38:31
If the 430 is the same engine as 530, what is different to up the horsepower. Can my 430 be "powered up"?
Roger (Mi)
08-28-2004 21:30:20
 Re: More horsepower from 430 in reply to hiway, 08-28-2004 09:38:31
If it's gas, there is not much that can be done without changing the engine. The 430 gas has 148 CID and 35 HP, 530 has 159 CID and 43 HP, and the 630 has 188 CID and 52 HP. If it's a diesel, the increase in horsepower is simple. The 430, 530, and 630 diesels are all 188 CID. The difference in horsepower comes from the the injection pump settings. Turn off the fuel valve, remove the injection pump timing cover, line up the timing marks, remove the injection pump. Take it to any diesel pump service center and have it reset to either the 530 or 630 specs. Put it back on, line up the timing marks, and let it roar. Remember, the 430 cooling system is NOT as large as either the 530 or 630. Watch for over heating if you work it hard for an extended periods of time.
Camboted
08-28-2004 22:44:54
 Re: More horsepower from 430 in reply to Roger (Mi), 08-28-2004 21:30:20
Are the blocks the same between the 430 & 530? Couldn't he go to larger pistons and sleeves? I have a 400B, basically the same, and put oversize pistons in it and it dynos out at 42hp.
Roger (Mi)
08-30-2004 05:24:24
 Re: More horsepower from 430 in reply to Camboted, 08-28-2004 22:44:54
Yes, a good machine shop could machine the block to accept larger sleeves. I've never heard of oversized piston/sleeve sets specifically made for the 430. Of course, the head could also be machined to accept larger intake and exhaust valves too. Where there is a will, there is a way.
mike's600
08-28-2004 12:32:43
You can change the gov. spring to overpower the gov. operation. It will give you more rpms. You can remove the head , have it milled down for more compression.
