Case 1070 pulling potential
Earl W
08-26-2004 18:12:29
How much HP can you get out of a stock 451? How much if you add a turbo and what turbo would be the best? How much can the powershift trans. take before it blows apart? Any info on this would be great and any pulling case info in general would be great. THANKS!!!
deller
08-26-2004 19:36:26
 Re: Case 1070 pulling potential in reply to Earl W, 08-26-2004 18:12:29
Back when the 70 series came out a customer of mine pulled a 1070 power shift. Not sure of horsepower, but he added a turbo, injected cold water and alcohol mixture just ahead of the turbo. He turned the fuel screw in for maximum delivery in the injection pump. Ideally you may want to upgrade injection pumps. Transmission wise, Bolt the torque limiter to the flywheel by drilling through limiter plate and tapping into flywheel. 4- 5/8 inch bolts should work. Raise the transmission clutch pressure to 250-300 psi. This should get you started. Do not use too much alcohol in water mix. ,you will melt holes in the piston. He used a fuel oil nozzel to spray mixture into turbo intake.
Kansas_Farmer
08-26-2004 20:42:57
 Re: Case 1070 pulling potential in reply to deller, 08-26-2004 19:36:26
You'll burn holes in the pistons with just the turbo and the fuel turned up. Don't ask Dad how I know that....(it was a 5010 Deere, but the principle is the same, neither engine has oil cooled pistons)
If ya do it, put an EGT gauge on it with the probe in the manifold ahead of the turbo and don't exceed 1200* for very long. M & W used to make turbo kits for tractors, that's what's on our 5010. You might be able to find one. Otherwise a T3 or KKK turbo would be about right I think.
