leaking hydrolics on 430
hiway
08-26-2004 05:17:59
my newly purchased 430 has a huge leak at the short upper arms. (rockshaft..I think it"s called) New to tractors, what is it and how"s it fixed? Thanks guys.
Roger (Mi)
08-28-2004 21:41:05
 Re: leaking hydrolics on 430 in reply to hiway, 08-26-2004 05:17:59
If hydraulic oil is coming out of the rockshaft arms, the rockshaft piston seal needs to be replaced. The oil is being transfered from the torque tube to the rear end. The rear end should only have 90W or 85-140W gear lube. It should be no higher than the mark on the rear end dip stick. Remove the rockshaft cover, and replace the piston seal.
