680 case ck pinion gear altrenative
Terry Bigda
08-25-2004 17:50:06
My 680 Case Ck has a pinion gear that has little if any gear left on it. I have searched high and low for over a year for a replacement (G-14420)with no luck. Can I use any other pinion and ring gear set in this unit so it will move at some speed.
Thank you for your reply
Terry Bigda
Doc Holiday
08-26-2004 20:29:56
 Re: 680 case ck pinion gear altrenative in reply to Terry Bigda, 08-25-2004 17:50:06
Just my .02
We have locally a machine shop that rebuilds bull pinion and diffential gears for heavy equipment.
I have personally had broken off teeth of bull gears repaired by this shop and never had problems with the gear over the course of many years.
You might check around with your local machine shops for someone in your area that might be able to help you out.
I happen to have a 680ck of my own that I am looking for the right hand brake acutating lever as well as one of the self leveling cutout valve control rods.
Doc
jcmarleau
08-25-2004 20:03:39
If you find any let me know the same thing here over a year looking for one. my e mail is [email protected]
