430 steering gearbox
Patrick (Mich.
08-25-2004 10:21:32
I have a 1961 model 441 wide front tractor, and I am running into difficulty with the manual steering gearbox. It appears that the oil seal on the wormshaft has been leaking oil for several years. The oil seal is located in the bearing cover which slides over the wormshaft. When I inquired at the dealer, I was told that the seal is no longer available. I checked at Detroit Ball Bearing, and they said that they don't even have a seal for that size shaft (.890"). So my questions are: 1. Have any of you also had to deal with this? 2. Were you able to get a new oil seal? (Is this part ACTUALLY obsolete?) 3. How in the world does that seal even come out of the housing? Thanks for any help!
