VAC hydraulic pumps
vac owner
08-24-2004 21:36:20
I have a newly rebuilt vac motor with a tansmission that pops out of gear when pulling a load (1949). Also, after removing the disc brakes, I discovered both sides of the housing inside are cracked. So I have decided to change rearends. I already have another rearend without the eagle hitch (like the one that I already have), but I would like to have the 3pt hitch. I found another VAC (1951 with eagle hitch)about an hour from my house that the guy is willing to sell me cheap so I think that I'm going to buy it and try to recondition it to go with my rebuilt motor. My question is this, how hard is it going to be to get the hydraulic system going on the 1951, assuming that it needs everything overhauled? Are parts available for the pump mounted up on the front of the block? Can a person with a few ordinary tools rebuild one themselves? How about parts/seals etc. for the lift cylinder behind the seat?
Would I just be better off just fabricating a three point hitch (I have seen several done on early VAC's) and using the torque tube hydraulic pump to actualte a hydralic cylinder? Which hydraulic pump is better? Any advice would be appreciated.
F-I-T
08-25-2004 14:43:30
 Re: VAC hydraulic pumps in reply to vac owner, 08-24-2004 21:36:20
vac owner:
Can"t h elp you on the gear popping out. Perhaps it a spring ball detent problem.
My "50 has the Eagle hitch. and it all pretty straight forward, and doesn"t take any super skills. All the seals and such that I have had to buy havebeen available through the dealer, but the problem iis finding the correct part numbers! Lots of folks here helped out with that.
As far as how hard to get the "51 rear end spiffed up, probably not hard at all. I would look closely at the rear axle seals while you are there.
Frank
