Case CC Rear stuck?
Jason Senecaut
08-24-2004 13:35:59
Hello all....started working on a couple of the old Case's. Got my '43 SC going good again after sitting for 10 years, but my '35 CC seems to have the rear stuck. Tires were all flat (yes, it has rubber on it now, steels were taken off), so I aired them up, and tried to pull it out of the shed to work on it in the light. Won't budge. Just kinda rocks and shimmies when I pull on it. Ant ideas? Yes it's out of gear ;)
Jason Senecaut
08-25-2004 12:49:11
 Re: Case CC Rear stuck? in reply to Jason Senecaut, 08-24-2004 13:35:59
update: Ok...I looked at the owners manual for the CC before I went back out today. Guess what? It's got a hand brake (hand slaps head) Doh! Took that off and it rolled so smooth, I could just about do it by hand. LOL Oh well...I've never messed with this tractor and it was dark in the shed...thats my excuse and I'm sticking to it :)
C. Amick
08-26-2004 09:46:45
 Re: Case CC Rear stuck? in reply to Jason Senecaut, 08-25-2004 12:49:11
Well, at least the brakes work. :)
RoyG
08-24-2004 18:06:09
Just a wild guess, it it is not stuck in two gears then from sitting for a long time and all the oil drained off top trans shaft bearings and locked up. Have had to loosen bearing caps before to get one to roll.
Jason Senecaut
08-24-2004 22:17:54
 Re: Case CC Rear stuck? in reply to RoyG, 08-24-2004 18:06:09
well, don't know what you mean by stuck in two gears, but I can shift into first and third, but not reverse or second....I'm assuming they are just not lined up though? Gonna check it out better in the morning. I'll check the fluid level in the diff/trans, and jack it up to see if either tire can spin.
