Hard starting 685 diesel
CampRunFarm - E
08-23-2004 19:27:18
Does anyone have any thoughts on why an International 685 diesel is hard to start even in warm weather. The first time it is started in the morning it is very hard to start, after that it starts fine??
Thanks, I would appreciate any info.
CEB
08-24-2004 12:00:31
 Re: Hard starting 685 diesel in reply to CampRunFarm - Ed, 08-23-2004 19:27:18
I have a 684, which is essentially the same tractor. I had the same problem, except the tractor was hard starting all the time. I overhauled the engine. When I took the head to the machine shop, the guy at the machine shop said "I bet this tractor was hard to start". I asked him how he knew that. He said that all the valves were bad. He said it was cheaper to put new valves in than try to regrind the old ones to the proper angles. He was right. Now the tractor starts instantly, even in cold weather.
I don"t know if this is your problem, as several other factors, like poor compression, worn injector pump, etc. can also cause hard starting, but it is worth considering.
