VAC questios?
Camboted
08-22-2004 20:48:44
Who can tell me about the differences between late model VAC-14 and VAC-13?? How were they different form the 49-51 VAC's that had eagle hitch?
Ryan
08-23-2004 20:44:38
 Re: VAC questios? in reply to Camboted, 08-22-2004 20:48:44
According to my manual (case reprint) Les is right.
VAC-11 Single Front Wheel Narrow
VAC-12 Double Front Narrow
VAC-13 Fixed Wide Front
VAC-14 Adjustable wide front with low easy ride seat.
Ryan
08-23-2004 21:06:42
 Re: VAC questios? in reply to Ryan, 08-23-2004 20:44:38
Need to amend my post.
VAC-13 had an adjustable wide front.
Designations started with tractor 5570001
Richard
08-23-2004 18:52:54
there were a lot of littile changes over the years if you had a yard full you would see.The vac 14 was called sweet and low by case if you look at old adds.vac14 had low floor plates and the wide front ends were set back ,norrow front was an option as were 34 rear tires.
Les...fortunate
08-23-2004 04:51:53
It's my understanding that the 14s had an adjustable wide front and the 13s were fixed.
Jerry W
08-23-2004 08:10:17
 Re: VAC questios? in reply to Les...fortunate, 08-23-2004 04:51:53
I thought that a VAC-14 had the 28 inch rubber and that the VAC-13 had the 34 inch rubber. My dad's VAC-13 which my great uncle bought new in 1953 has an adjustable axle and as far as we know it is original.
I though that the VA had the rigid front axle.
By looking in the parts book the front axles are the same for the 13 and the 14 except for the spindle housings.
Late model VAC's have the steering geat box upfront in the bolster and the early ones have it on the top of the torque tube and then a steering pushrod arm up to the front end.
Jerry
Les
08-23-2004 18:38:59
 Re: VAC questios? in reply to Jerry W, 08-23-2004 08:10:17
You may be right about the rubber sizes. My '52 VAC (I guess it would be a VAC 12) has 34 inch rubber. I'm looking at another '52 VAC which has an adjustable wide front and 28" rubber. Serial # is only 50 higher than mine.
