rear axel on 730 870
Mikey
08-22-2004 17:11:55
I have a 1966 730 CK (gas w/3653 hours) & a 1974 870 AK (Diesel w/3276 hours) w/no power shift. My dad bought both tractors new and both are working tractors. The 730 has a model 70 loader on it and is used for general use and plowing snow here in Wisconsin. The 870 is used only in the summer now for mowing weeds & grass. Both tractors have been shedded all of their life. My question is that when we were still farming, in 1973, we pulled a 4-16 IH plow and had to move the rear tires out 3-4 inches so the first bottom would turn over correctly. In fact the right-rear is out farther on both tractors than the left-rear. Both tractors are "family" and are in the shop right now for other repairs (the 730 is stuck in 3rd gear, and the 870's PTO is stick ON and I can't turn it OFF. I told them to move the rear wheels on both tractors back to the "factory specs". Does anybody know what the "factory specs" are or should I go by the paint on the axle. That's kinda iffy, due to age; rust, and a replacement axle on the 870. ANY help would be greatly appreciated.
mikey
08-22-2004 23:07:13
 Re: rear axel on 730 870 in reply to Mikey, 08-22-2004 17:11:55
I forgot to mention, the 730 has 15-5-38"s and the 870 has 18-4-34"s.
Steve G
08-22-2004 19:15:16
When I worked for a case dealer we would set the tires up for the width of the row. In otherwords if you had thirtyeight inch rows that is what the tires were set at. This was measured from the center of the tractor (pto shaft) to the center of the tire. If you had thirtysix inch rows it would be 36. There was no factory spec just the row spec. So set them up for the row width you have now. By the way I grewup with both those tractors and have alot of memories that came back. Use and enjoy!
Mikey
08-23-2004 14:14:12
 Re: rear axel on 730 870 in reply to Steve G, 08-22-2004 19:15:16
I am no longer activly farming, but will be keeping both tractors for yard and miscellaneous work. Back when I was farming, both tractors were set for 38" rows, as I had a John Deere 494 planter. I suppose I could set them to the modern row width, which I think is 24", is that right, or is it 30"? That way it would be more usefull for many years to come.
Jim B
08-22-2004 19:01:41
My guess would be that "Factory" axle width settings would be fully inboard ... but only to make shipping more feasible and cheaper. I happened to at my local Case dealer earlier this year when a flatbed truck load came in and all rear wheels adjusted narrow. The dealer, or customer would move them where required depending on impliment requirements.
Tom (Ks)
08-22-2004 20:19:29
 Re: rear axel on 730 870 in reply to Jim B, 08-22-2004 19:01:41
If the farmer did not care, we would set them out to 34 or 36 inches, to make it easy to work on.
