Case SC and CC Sleeves Pistons.
JA in OK
08-22-2004 16:57:47
I have a Case SC that needs sleeves and pistons. I have also located a Case CC for parts. Will the CC sleeves and pistons fit in the SC block?
Is any machine work required?
C. amick
08-23-2004 09:42:13
 Re: Case SC and CC Sleeves Pistons. in reply to JA in OK, 08-22-2004 16:57:47
If you can locate a set of used SC pistons, you can probably get sleeves made for them. I am told that Case/IH still stocks 3-5/8" pistons and sleeves for the SC.
SteveG
08-22-2004 19:19:17
They are two different bore sizes and the wrist pins and rod assemblies do not interchange. If you had aD series it would work but not to an S series
no
08-22-2004 17:38:09
no
