wiLL NOT START,
gILBERT
08-22-2004 15:08:14
i HAVE THIS CASE TRACTOR, BACKHOE, LOADER WITH DIESEL ENG.188. i GOT IT AS A BASKET CASE ENGINE, NEEDING RINGS AND ROD INSERTS. i WAS TOLD BY THE PREVIOUS OWNER THAT THE PUMP WAS REBUILT, BUT i TOOK IT INTO THE SHOP AND EVERYTHING MOVING PARTS WAS STUCK. THE MAN REPLACED AND REPAIRED EVERYTHING. i PUT IT ON TIME. i WAS A MECHANIC ON TRACTORS FOR 40 = SO i THOUGHT i HAD ALL THE PROBLEMS THAT WENT WITH TRACTORS BUT THIS ONE IS BAFALING. i TOOK MY COMPRESSOR TOOL AND STUK IT IN NUMBER ONE FOR CAOMPRESSION ON #1 AND IT INDICATED THE WE WHERE AT 8 AFTER ON THE FLYWHEEL. wE EVEN TRIED IT AT THAT AND STILL NO LUCK. HAVE ANY SUGGESTIONS. WAIT TO HEAR FROM YOU IF THIS IS ENOUGH INFORMATION.
RoyG
08-22-2004 16:13:38
 Re: wiLL NOT START, in reply to gILBERT, 08-22-2004 15:08:14
188 times at 8 degre before top dead center. Set flywheel mark at 8 btc and align two marks in pump and after blead in she should start riight up. email me if you have any trouble
