Case 440 foamy hyd. oil
DaveMarshall
08-21-2004 16:45:51
I figured I best post in the Case forum for this problem. I bought a Case 440 recently and the 3pt. hitch won"t lift. The hyd. pump makes a lot of noise (cavitation?) and when I cracked open a fitting to try and bleed the system all I got was a "burp" or two and lots of foamy hyd. oil. Any suggestion"s on what to look for? Do the tranny and the hyd. system share the same fluid resevoir?
Terrance
08-21-2004 17:24:51
 Re: Case 440 foamy hyd. oil in reply to DaveMarshall, 08-21-2004 16:45:51
Dave,
It sounds like you are low on hydraulic fluid, the transmission and the hydraulic system do NOT share the same resevoir.
The transmission/transaxle has a dipstick behind the 4 speed shifter on top of the housing on the left, it is a large hexshaped plug. The transaxle uses 80/90 gearlube.
The Hydraulic reservoir is under the instrument panel on the triple range shifter cover it is usually a plug that thakes a 1/2" square drive ratchet.Use Tractor hydraulic oil in the hydraulic system. You should not have to bleed the system.
Hopr this helps
Terrance
deller
08-26-2004 20:20:59
 Re: Case 440 foamy hyd. oil in reply to Terrance, 08-21-2004 17:24:51
You might want to double check your manual. I believe most of the hydraulic systems on these units used 30W motor oil. Hydraulic oil will foam.
DaveMarshall
08-23-2004 20:58:56
Thanks Terrance. I"ll check these two things out right away.
