Case/IH 235 Hydraulic Problem
Joe
08-21-2004 12:58:58
Hi, I'm new to this so please bear with me. I have a Case/IH 235 (Gear Transmission) I bought used. It has 1200 hr on it. I was mowing with a 4ft three point hitch mower (I've used in the past with no problems) when the three point hitch would no longer raise. This happened suddenly with no previous indication of a problem. I removed the mower, the three point hitch still wouldn't raise. I'm able to freely lift the arms by hand, even with the select lever in the "HOLD" position. I've checked the oil level. I think the problem is in the linkage. Has anyone had a similar problem, I'am open for suggestions before I go any farther. Thank You.
Scott KY
08-21-2004 14:52:57
 Re: Case/IH 235 Hydraulic Problem in reply to Joe, 08-21-2004 12:58:58
Make sure the knob in front of the seat is in the open position. If the knob is turned off the hitch will not raise.
Joe
08-21-2004 19:02:29
 Re: Case/IH 235 Hydraulic Problem in reply to Scott KY, 08-21-2004 14:52:57
Just received my Case Service Manual (what a disappointment for the money). I had turned the flow control knob to different positions earlier without success. I did not mess with the adjusting screw on it. I don't fully understand the instruction in the service manual. I'am going to re-read this and see if I can make sense of it. Thanks for the tip, I'll let you know how I make out.
