DB 1212
gregny
08-21-2004 12:26:58
Have a 1212 that suddenly stopped moving. Was roading equipment through town on dead flat ground when it suddenly went to neutral. Quite embarassing sitting in the center of the business district in front of the bank holding up traffic. Tractor has the regular gear transmission with a 4 speed hydraulic range transmission. I'm assuming the hyd unit trans might have given up the ghost as there was no warning signs of any type, just KAPUT, and there it laid. Also, if anyone has any service info relating to overhaul, pressure checks, and troubleshooting, even an operator's guide to this hyd transmission, i would like to hear from you, as the old IT manual I have doesn't show or discuss a thing. Thanks, all.
Elmer
08-21-2004 19:23:48
 Re: DB 1212 in reply to gregny, 08-21-2004 12:26:58
I would bet that the clutch disc hub had tore out. Even if you lose hydraylic pressure you will always have low gear. Both brake bands on the two planetaries are engaged when hyd press is dropped.
JCMarleau
08-21-2004 19:18:50
Can help you have service manual from D>B my e mail is [email protected]
