case 400 diesel pump
TLS
08-21-2004 01:19:45
thanks for the interest I am sorry I worded it wrong I was actually refering to the injector pump on the case 400 diesel can anyone help me find one?
John Saeli
08-21-2004 06:01:29
 Re: case 400 diesel pump in reply to TLS, 08-21-2004 01:19:45
Hey TLS: One of those pumps just sold recently on e-bay cheap. If you don't find 1, keep an eye on e-bay. Go to "CASE Parts Injection Pump".
fPat T
08-21-2004 06:48:44
 Re: case 400 diesel pump in reply to John Saeli, 08-21-2004 06:01:29
It went cheap because the seller didn't know if it really worked or not. I quit bidding at $50 because of that. Probably would have gone a lot higher if it was stated to be a runner for sure.
Doc Larry
08-21-2004 08:18:54
 Re: case 400 diesel pump in reply to fPat T, 08-21-2004 06:48:44
If I may make a suggestion.
Are you absolutely certain the injector pump is faulty? Many of the older tractors have sat for years with fuel in the system and have extensive gum deposits. The primary screen filter in particular is very easily clogged and may need to be repeatedly soaked in a mix of alcohol and acetone and blown out with compressed air to be cleared. If the tank and lines are not cleaned very well at the same time, the filter will clog back up very quickly.
After cleaning, the bleeding procedure must be followed carefully. The needle valve on the outlet side of the primary filter must be open for bleeding and closed for operation. If the needle or seat in this valve are bad, the fuel gear pump will circulate fuel through the lines rather than supply fuel at proper pressure to the injector pump, so I recommend checking this valve carefully.
Be very careful to avoid getting anything into the fuel lines upstream from the final filter.
If any of the above are a problem and you do get the tractor running, expect it to miss and spit for a while until the fuel system gets flushed out.
On the plus side, I picked up my 401 for a song because "one of the best diesel mechanics in town" declared it in need of an injector pump and the owner didn't want to put $1000 into a rebuild. In fact, the problem was a clogged primary filter and inoperative vacuum gage..... .
Good luck,
Larry
