CC Case tractor color help needed
Patrick
08-20-2004 10:30:52
My grandfather and I are restoring a CC Case (1939). He says when his father bought a similar CC Case new years ago, it was a dark bluish grey color. Does anyone know where we can locate this color of paint or the story behind why it was painted this color?
Dan in Ore
08-22-2004 10:28:21
 Re: CC Case tractor color help needed in reply to Patrick, 08-20-2004 10:30:52
I was at a show several years ago and saw a blue CC. I just thought the guy was off his rocker. Never talked to him about why he did it, but there may be something to your grandfathers story.
Dan
DCTOM
08-21-2004 07:20:39
THE LC GRAY PAINT ON C AND L TRACTORS HAD A TENDENCY TO FADE TO A SLIGHT BLUISH COLOR BUT THE CORRECT COLOR WAS DARK GRAY LC GRAY IS THE CORRECT COLOR
Brian in Ohio
08-20-2004 11:11:12
CCs were painted Case LC grey. I'm not certain what the codes are for mixing it, but I think you can still acquire it from a Case dealer. The old part number was B-13017.
M Witheft
05-24-2005 18:47:46
 Re: CC Case tractor color help needed in reply to Brian in Ohio, 08-20-2004 11:11:12
can anyone give me the color code for the correct color for a 1936 cc case.I am sure it was bluish grey but with out the color code it is almost imposible to get it mixed.
Patrick
08-20-2004 17:53:52
My grandfather distinctly remembers the tractor being more of a darker smokey blue type color. He talked to another man some time ago who also remembered having a blue cc Case. He also read in a book that at one time they did paint some tractors a different color to use up paint. Any insight on such a practice? He has found pictures in tractor books showing tractors (CC & L) in the bluish color though nothing is mentioned about it appearing to be another color than grey. Mystery??
Brian in Ohio
08-20-2004 18:55:53
 Re: CC Case tractor color help needed in reply to Patrick, 08-20-2004 17:53:52
This is the first I've ever heard of a C or L series with a blue tint to it. It wouldn't surprise me, but I've never seen one. If you have your paint mixed, you could probably have them add a touch of blue to it to give it a more distinctive look. As it has been posted on this site many times, it's YOUR tractor, paint 'er pink if you want to... :)
Tom (Ks)
08-20-2004 19:10:21
 Re: CC Case tractor color help needed in reply to Brian in Ohio, 08-20-2004 18:55:53
When I dismantled my 37 CC it had blue paint under the deck where you put your feet. I don't think anyone would take the time to paint it that color under there.
