SC Ring Gear
Glenn FitzGeral
08-19-2004 22:36:04
Took the SC ring gear out tonight...Badly worn in two places. Apparently it's been turned 180 degrees already. DCtom has turned DC ring gears around but can a SC one be turned around? If so mine will work as none of the gears are more than half chewed off. I have not looked much for a new one yet. Starter drive isn't real good either. I will be replacing that. Anyone successfully flipped a SC ring gear? Thanks, Glenn F.
Glenn F.
08-20-2004 16:22:43
 Re: SC Ring Gear in reply to Glenn FitzGerald, 08-19-2004 22:36:04
Archives stated Checker Auto parts can get them. I checked today. New ring gear for $45.99. They can get it in 3 buisness days. Sounds good to me.
Paul f
08-21-2004 06:11:40
 Re: SC Ring Gear in reply to Glenn F., 08-20-2004 16:22:43
Glenn: If you are going to the trouble of splitting the tractor I would spring for the new ring gear...it will probably outlast you.
It is interesting that engines tend to stop at the same point most all of the time (or at a point 180 Degrees away) ..hence the wear you see is limited to a very few ring gear teeth. and a similiar wear point at the opposite point on the ring. I guess if you want to reuse a 90 degree rotation of the gear would work..
