Need Gaskets!!!
JR
08-18-2004 15:01:45
hi guys! i am into my DC4 and need some gaskets... if anyone can help. i need the transmission cover gasket, the bell housing gasket, axle gaskets, and the rear cover (tractor has eagle hitch) and any on the rear half that i forgot to mention! thanks!!!
Dave in WI
08-19-2004 10:18:36
 Re: Need Gaskets!!! in reply to JR, 08-18-2004 15:01:45
Hey JR,
Order some gasket material from MC Master Carr or Grainger, and make your own. Thats what I do all the time. And for the really bad covers That leak even with new gaskets made I use a little high temp silicone that I use on the intake manifolds of my cars.
Works aawsome
Dave
John Saeli
08-18-2004 19:34:33
Hey JR: I tried to get the Top Cover gasket for my SC last week & the dealer told me they were no longer available. The SC & DC are the same gasket.
Paul f
08-18-2004 17:26:45
JR: I got the PTO gasket O9031AB new #A27588 from Case, and the PTO housing top gasket O9030AB new #A27587 from Depot Parts via Case dealer.
08-18-2004 16:18:12
SILICONE
Pete
08-19-2004 10:03:02
 Re: Need Gaskets!!! in reply to [email protected], 08-18-2004 16:18:12
NO SILICONE!!! It blows!!! (at least oil past it.) Permatex - Brown stuff that brushes on or comes in a tube in a paste like form. It stays pliable and does not leak. I have not used silicone for years now that I switched to Permatex.
JR
08-19-2004 16:43:57
 Re: Need Gaskets!!! in reply to Pete, 08-19-2004 10:03:02
Pete, do you mean the hi tack brownish red stuff? thaks!!!
JR
08-18-2004 16:50:16
thats what i originally thought, but on the back cover especially, with as hard as it is to take it off to do this, i would rather not do silicone. otherwise, thats a great cure-all! thanks again!
DCTOM
08-18-2004 17:50:46
 Re: Need Gaskets!!! in reply to JR, 08-18-2004 16:50:16
I DO IT ALL THE TIME AND HAVE NO PROBLEMS BUT TO EACH HIS OWN DCTOM
todd hamilton
08-18-2004 20:15:28
 Re: Need Gaskets!!! in reply to DCTOM, 08-18-2004 17:50:46
I've got silicone on the cover plate for the oil screen on the side of the pan on the SC. That plate and the valve cover (I suspect the fellow who fixed up the tractor used silicone there) are the only two places where I don't leak a little! I've got Seal-All on the brass fitting in the gas tank where the bowl screws in. I have not seen an SC yet that didn't seep gas through that thing. The mold for those fittings at the casting plant must have been made out of sponges!:^)
jal-SD
08-19-2004 06:21:12
 Re: Need Gaskets!!! in reply to todd hamilton, 08-18-2004 20:15:28
Todd, the sediment bowl flange is soldered into the tank. I think the solder deteriorates. We took a tank to the radiator shop & the guy re-soldered it - no leaks! (My $0.02 worth. jal-SD)
todd hamilton
08-19-2004 19:42:38
 Re: Need Gaskets!!! in reply to jal-SD, 08-19-2004 06:21:12
I didn't consider or know that it was a soldered fitting. Makes sense - thanks for the advice, worth more than 2 cents!:^)
