Setting Case 500 Valves
Walter
08-17-2004 17:37:22
My mechanic informs me that although we have the settings on the intake and exhaust valves for the 500, I think they are .012 and .012, we also need the sequence for setting them. What is he talking about, we can't find that in the manual.
Doc Larry
08-17-2004 20:22:16
 Re: Setting Case 500 Valves in reply to Walter , 08-17-2004 17:37:22
Walter,
Each valve needs to be set with the corresponding cam at the lowest position. The owner's manual should indicate which specific valves are to be adjusted relative to the position of the timing mark on either the flywheel or front pulley. If the owner's manual doesn't, the service manual will, but I'm almost certain your owner's manual has this information in a section entitled "Valve Tappet Clearance". This should be in the text, not just in the specifications chart.
If you have a diesel be sure the compression release is fully off.
Doc Larry
