Which VA is it?
Steve from PA
08-17-2004 14:58:45
I just bought a basket case, no pun intended. The serial # plate has been missing from it for many years. It has a fixed wide front with the straight steel axle with a nub welded on where the pivot pin mounts, 28" rear wheels, and non-adjustable rear tread (unless you turn the rims around). It also has the hydraulic pump mounted where the belt pulley would be. It is lacking the casting for the eagle hitch which I believe makes it pre-1950. The guy who sold it to me had it advertised as a VAI, but I have a 1952 VAI and it has 24" rears, and the front axle is cast with a slight curve in the center. My VAI also came with the engine mounted hydraulic pump. Other than those features, they are very similar. I was thinking it might be a VA. Anyone have a guess as to what it might be? Thanks in advance...Steve
Arthur
08-18-2004 06:49:08
 Re: Which VA is it? in reply to Steve from PA, 08-17-2004 14:58:45
If the front axle is 2",or 1.75" X 3",it's a VAI. If its 1.5, its a VA
Steve from PA
08-19-2004 14:09:18
 Re: Which VA is it? in reply to Arthur, 08-18-2004 06:49:08
Arthur, It is neither of those. It measures 1.25" wide by 2.5" tall. Confusing isn't it?
Joe (Wa)
08-17-2004 22:51:13
Case parts manual E61 lists both fixed wide front axles you described for VA series tractors. The axle change was made after VA series serial nr 5657999 (1952) and VAO #5656107.
The eagle hitch with engine driven hyd pump was available in 1949 but I believe it was standard equipment only on the VAC that year.
So I guess we are back to square one, VA or VAI.
Joe
Richard
08-17-2004 18:52:20
It sounds just like the 49 va that I have in the back yard. You didn't say , does it have high or low floor plates.
Steve from PA
08-19-2004 14:03:28
 Re: Which VA is it? in reply to Richard, 08-17-2004 18:52:20
Richard, Sorry it took so long to get back. Computer trouble. It has the high foot plates. It also has the old style implement lift with the single cylinder mounted under the dash mount.
