Vac rearend weights
Vac owner
08-17-2004 14:32:14
I currently have a 1949 Vac, of course without the three point eagle hitch, that I can pull in the 2500lb class in the antique pulls after stipping the tractor a bit. The problem is that the rearend is badly worn and I am going to replace it. I found a '51 Vac with the eagle hitch that is reasonable. If I take out the four bolts holding on the lifting assembly and take it off, is the newer rearend casting heavier to accomidate the eagle hitch? I don't want to gain any more weight, but I would like to use that rearend so that I can use that flat spot and four bolt holes to rig up a hitch and weight bar system. Thanks
