Case Vac-14
Victor VanSickl
08-17-2004 05:14:55
I just aquired my Grandfathers old Case Vac-14 serial 6013942. I am new to the game and need to know if it is a positive ground , it still has a 6 volt system.
Victor
08-26-2004 08:55:03
 Re: Case Vac-14 in reply to Victor VanSickle, 08-17-2004 05:14:55
Hey Guys just thought i would let you know i got the case running. I had power to one side of the points but was not making good contact.I took a piece of sand paper and cleaned them and had good fire, took the carb off and cleaned it and she fired up. Other than a leaking water pump and a dragging starter im in good shape. I called a dealer and they said the starter was NA but the water pump is. Any suggestions on rebuilding starter.
Victor VanSickle
08-20-2004 13:31:28
Yes the points are opening but i seem to not getting spark from the coil. Ill have to get my multi tester and do some more checking.
Jerry W
08-18-2004 05:30:44
Are the points opening and closing or are they possibly shorted? Is there current in the primary coil circuit?
Jerry
Victor VanSickle
08-18-2004 05:13:31
Okay guys you were right it is still pos ground but now i am not getting any spark. I have replaced the battery and coil and it turns over but wont fire. I pulled the coil wire off and get no spark.
Augie
08-17-2004 09:23:21
Positive ground is the original configuration.
C. Amick
08-17-2004 09:21:38
Yes, it came from the factory, positive ground.
