Case 400 diesel fuel pump
TLS
08-17-2004 04:53:04
can anyone help me source a main inline fuel pump for a diesel case 400?
Dale in Ar.
08-18-2004 08:40:48
 Re: Case 400 diesel fuel pump in reply to TLS, 08-17-2004 04:53:04
I maybe mistaken but the 400 series diesel does not have an inline fuel pump.I looked through my parts manual and service manual and didn't find anything suggesting aan in line fuel pump.The injector pump is the only pump that the 400 diesel has on it and is gravity fed.I could be wrong,it happened once but then I do forget,old age.
Doc Larry
08-18-2004 20:12:54
 Re: Case 400 diesel fuel pump in reply to Dale in Ar., 08-18-2004 08:40:48
On the 400, fuel travels from the tank through the primary filter and to a gear pump built into the side of the injector pump. The gear pump then supplies fuel at low pressure up through two more filters and then to the injector pump itself.
If yours has an inline pump it's probably aftermarket
Larry
