LA Case Timing
walter
08-16-2004 18:25:59
Has anybody come up with a good way to adjust the timing on an LA? The original mag had adjustable timing built into the mag. Aftermarket fixed time mags may come close but if you want to fine tune it for pulling etc. its tuff to adjust. I tried turning the whole housing by removing the set screw and jam nut and rotating the governor housing to advance or retard the timing and then replacing the original set screw with a flat nose regular bolt and tightening it. I didn't know if this would hurt anything. An alternative would be to cut slots in the mag mounting braket where it bolts on to the gov housing. This would require a trip to a machine shop. Any help or suggestions appreciated. Thanks!
RoyG
08-16-2004 19:11:08
 Re: LA Case Timing in reply to walter, 08-16-2004 18:25:59
All you have to do is take a 1 1/4 inch end wrench and loosen the mag drive and turn it. It has knotchs. The Case Mag did not have adjustable timing in the mag. You had to adjust it this way. True you could retard it with the lever but that just retaded the time the points opened and did not change the armature timing.
Walter
08-17-2004 17:40:42
 Re: LA Case Timing in reply to RoyG, 08-16-2004 19:11:08
I'll give that a try but I thought the drive coupling was on a keyed shaft . Thanks.
