filling lp tank
ky ted
01-09-2006 05:41:44
was wondering how other people fill their lp tanks on their tractors. thanks
Marty K
01-10-2006 07:42:52
 Re: filling lp tank in reply to ky ted, 01-09-2006 05:41:44
I have 5 tractors, mostly 1950s vintage, all on factory LP - JD720, MM UTU, MM GB, Farmall 450, and Case LA. I used to bleed the vapor into the atmosphere when filling (and we did it that way all my life growing up on the farm), but I don"t do that anymore. I hook the wet line of the big tank to the tractor and open the valves and leave it overnight. The thermal expansion of the two tanks (with a check valve in the tractor tank) allows them to fill without releasing any vapor into the atmosphere. Being play tractors (for the most part), I"m not in a terrible hurry to fill a tractor.
D17JIM
01-10-2006 02:54:32
BE CAREFUL IF YOU VAPOR ONE OFF TO FILL IT. YEARS AGO WHEN I HAD A 1977 FORD 250 TRUCK ON LP GAS I WAS VAPORING IT OFF AND AN ELECTRIC FENCE SPARK ACROSS A HOG LOT FROM ME SPARKED AND SET THE VAPOR OFF. TRUCK BURNED UP AND I SPENT 2 WEEKS IN THE HOSPITAL. WARM HUMID DAY AND VAPOR WAS CLOSE TO THE GROUND AND TRAVELED A LONG DISTANCE TO THAT SPARK. TRUCK WAS ONLY 1 YEAR OLD AND TO THIS DAY THE ONLY NEW TRUCK I EVER OWNED. LOVED THE WAY THE TRUCK RAN ON LP. DO IT RIGHT OR DON'T DO IT!!!!! !!
Jerry W
01-10-2006 05:03:40
 Re: filling lp tank in reply to D17JIM, 01-10-2006 02:54:32
In my opinion LP gas is no more dangerous than gasoline. We fueled them for many years and never had a problem.
Jerry
wilson
01-09-2006 10:38:19
if you are concerend about leaving bleeder valve open run the engine on vapor only at half throttle while liquid line in attached. This will lower pressure in tractor tank. Hey DONT SMOKE
Jerry W
01-09-2006 08:51:56
If you are asking for the exact procedure, this is the ways we did it when I was a kid.
In order to fill any LP tank you have to create lower pressure in the tank you are planning to fill. Most old tanks have a lever and a percent full scale with a bleeder on it that will tell you how full your tractor tank is. Newer tanks merely have a guage and a separate bleeder. If the tractor is going to sit do not fill over 80% to allow for temperature expansion. If you are going to use it immediately you can fill to 90% or more.
You can do this in either of 2 ways.
I. Single hose method (not accepted by EPA) 1. Hook liquid supply hose up to tractor tank. 2. Open slowly valves and let tanks equalize - if tractor tank is really low this may be quite a gush. 3. Turn percent full lever to desired % and open bleeder. This venting of the vapor creates a lower pressure in the tractor tank and consequently liquid is forced thru the supply hose to your tractor. 4. Your tank is full when the bleeder starts gushing liquid or until gauge reads desired %. 5. Close bleeder - tank is full. 6. Shut all valves. 7. Bleed connections and unhook hose.
II. Two hose with pump method. In this procedure the pump can be either in the liquid line or the vapor line. You can either transfer vapor back to the supply tank or you can force liquid into the receiving tank. Some pumps may not be able to handle liquid. 1. Hook liquid/feed hose to liquid port and hook vapor/return to vapor port. The upper hook up is always vapor and bottom is liquid. 2. Open liquid valves and when pressure stablizes then open the vapor valves. 3 Turn percent full lever to desired % and open bleeder. 4. Operate hand pump until bleeder gushes liquid or until gauge reads desired %. 5. Close bleeder - tank is full. 6. Shut all valves. 7. Bleed connections and unhook hoses.
In the above procedures be careful if you are relying on a gauge. They sometimes repond slow.
Jerry
Camboted
01-09-2006 15:26:44
 Re: filling lp tank in reply to Jerry W, 01-09-2006 08:51:56
Jerry,
It always makes me nervous to bleed off the vapor. Too many guys smaoke over here. What kind of pump can be used? Will a centrufgal work, positive displacement, vane? I don't need some kind of fancy comercial job as this is for Cambodia, just somehing that works.
Jerry W
01-10-2006 05:00:58
 Re: filling lp tank in reply to Camboted, 01-09-2006 15:26:44
Ted
I really do not know what pumps would work. We had a pump that we bought from the local Farmers Union where we got the fuel. I would guess that it was LP rated but I really know nothing about it. From what I remember about it, it had the shape of a vane pump.
It has been over 35 years since I fueled LP tractor.
Jerry
wilson
01-09-2006 16:48:38
I dont know for sure but will one of the anhyrdous amonia pumps that run off vapor to power them work on propane ??? I never farmed with propane just light chore work with propane , but the method of running the tractor on vapor only while filling worked good for me as I was never in much of a hurry.
Engineer20
01-09-2006 07:36:04
I pulled my tank off with a loader and put it in the back of my truck and went down to the CO-OP and they filled it. They had to fill it off of the truck because the stationary fill hose on/off valve wouldn't clear.
Case1950
01-09-2006 06:18:25
So far I"m calling my gas company to do it. When I get a little extra cash, I"m going to buy another propane tank and get a wet line kit to fill them myself.
Case1950
wilson
01-09-2006 07:34:31
 Re: filling lp tank in reply to Case1950, 01-09-2006 06:18:25
where are you located I have a 500 gal for sale
Case1950
01-09-2006 17:30:51
 Re: filling lp tank in reply to wilson, 01-09-2006 07:34:31
I live in Georgia. I was thinking of getting a smaller tank than that. I only have one propane DC right now. I kind of like propane tractors and thought about getting more as money allows. I just got to find some money.
Case1950
