SC Pulley Brake
Glenn FitzGeral
08-15-2004 20:39:27
I'm going through the SC systematically. Tonight I discovered the brake drum on the pulley brake in two pieces, and the arm with the pad on it seriously worn. Both will need to be replaced. It is a foot clutch '54. Is such wear common? I don't suppose these parts are available new...? Are the pre-live power ones the same? I appreciate your feedback. Glenn F.
C. Amick
08-17-2004 09:50:39
 Re: SC Pulley Brake in reply to Glenn FitzGerald, 08-15-2004 20:39:27
I know someone that has a foot clutch tractor. The last time I was at this house, the clutch was stuck on it and he was smoking the belt pulley brake trying to free up the clutch. This is probably where the wear comes from. The pad can be relined, but I don't know what to tell you about the other part that is worn without seeing it. Could it be built up with brass? Do you have an old Case Dealer that you order parts from that could look up the part numbers. I'm in WV and the only one I know of here is High View Sales.
